BFL13 wrote:
2oldman wrote:
BFL13 wrote:
In fact, as Morningstar keeps saying, some amount of over-panelling is a good thing with an MPPT controller, since it does have the self limiter feature (unlike a PWM controller that will fry if heated up by over amping it)
What does self-limiting mean? Kinda sounds like throwing away power.
It means the MPPT controller will not go over its rated amps so as not to over-heat and fry if over-panelled. This comes from the way a buck converter works whether in an MPPT controller or as its own gizmo, AFAIK.
They do this by having a wattage input limit in its specs, but it might really be an amps limit, I am not sure. Morningstar talks about their amps limit in their specs, but that might be a watts limit, I don't know.
I don't have any info on how long it is wise to stay at max amps with a self-limiting controller so as to avoid heat damage. Just how long that would be in any day "depends" of course. Too many factors. I imagine most scenarios would be with just a short time mid-day, but you could end up with more of the day at that. Night-time shuts it down for however long that is.
the limit is normally defined by the power output stage on the low side ( the 12,24,48 V side) i know this having smoked quite a few in various designs.. :o
