MEXICOWANDERER
Oct 29, 2015Explorer
In quiescent mode they will use a small but perhaps (?) significant (aggregate total of) amperage. Worth appraising. Therefore switch the converter. I have had unfailing success with DROK brand buckers. Several have been functioning with LED lighting for thousands of hours. The voltage hasn't even drifted >.2 vdc. But I found output current in excess of 12 amperes really heated the devices, necessitating the use of a 40mm muffin fan. I chose 24 volt model fans as they screw a perfect amount of air over the booster or bucker at 12 vdc, are dead silent and consumption is negligible.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 24, 2026
