I could not think of anything else I could risk banking with my sixes that are getting near their end that would not get ruined. So these 27s won't have to last a long time. It is too early to just toss the 6s and get all new. The cheap used 27s won't be a waste of money by getting ruined sooner than normal time.
One thing I can do is follow the above advice and take it easier on them where possible. I do have some solar with them, which helps keep cycles shallow when sunshine happens.
I also will put them as the "downstream" battery banked with the 6s where the load and charging wires are on the 6s. The two 27s in parallel go as a big 12 in parallel with the 6s, making two 12s of approx. 200AH each. But by making the 27s downstream they will not be worked as hard as the 6s-- in theory.
I will separate the 27s for special attention whenever possible after a trip, and also now use 16v as mentioned by LY above, instead of just the 15.7 the VEC1093 can do.
I suppose it would be better to just use the 27s and not measure them. I don't bother with my car battery and it lasts for a few years despite what it goes through. These 27s only have to last as long as the 6s do. They are at approx. 87% of rated SOC based on recent 10 hr testing. (194 or so out of 226. Exide 135s--excellent service from these since 2011)
