BFL13 wrote:
Mex, good read. What do they mean by "generator charging"? No mention of a battery charger powered by the generator. Inverter mentioned. They refer to a charge controller and set points, so that would be solar.
What is their over-all set-up? Also their gen has an auto low voltage starter?
I usually look at trojan for charging parameters to follow when I cant find them for my specific batterys.
The 24's and 27's are similar with 14.82 bulk
13.5 float ( Thats a biggy and the PD is just too low @13.2)
16.2 EQ..
IDK why they suggest the generator ( inverter type?) is not efficient.
And looky 1.172 SG is 50% or 12.1v
http://www.trojanbattery.com/pdf/datasheets/27TMX_Trojan_Data_Sheets.pdf
