time2roll wrote:
lawrosa wrote:
Understood. 14.4 wins out..
So riddle me this..
I have these 12volters on the sears charger. Charging 10 amp setting @15.4 volts and 4 amps going in. SG is now at 1.250.
Its been 2 hours.
Can I conclude any information from this?
Why wouldnt the PD put in the amps @ 14.4? I know you say about the false voltage so just trying to grasp it.
Not yet fully charged. Look for less than 1 amp per battery to call full charge.
PD will put in the amps at 14.4, just slower.
You can get a PD-14.8 to be a little faster. Quite frankly I like the IOTA algorithm but it does take time. Fully charging also takes time. Fully charging a battery that has been bouncing up to 90% for a week or three takes more time. Boost charge to 90% is fairly quick as you get into 14.6+ volts.
It is an electro-chemical process. Not the same as filling your gas tank or winding a spring.
The whole thread was about lag, but is this a truth, or what scientific issue are we talking about.
Case in point. Me with these two 12v boat anchors...
5 hours on 15.3 charge @ 4 amps in. SG still 1.250. Not moving.
I give up.
Took off charger and hit button on PD. 14.4 volts, 1 amp in.
Will leave like this as I am frustrated. Maybe its normal. sg 1.250 is what? 90%? 85%? 80%?
So yes my batts will get to 1.275. Maybe in a few days, maybe not. but i've I seen it happen.
But the PD could not get them to said sg 1.250. It hovered in between 1.225 and 1.250 ( 1.242 ?) on an overnight charge on shore power. False voltages as mex stated?
If I cant them up on 17 hours plugged in, ill never get them up in the field with generator.
So to conclude.
Lag?
Batteries shot? ( but my drawdown test shows different in that respect.. Who knows... (" Third base? Whats on second? whos on first?.....Naturally!!!!!)
Beating a dead horse?
IDK reading old threads, all you gents here were a part of years ago, (2011-etc it seems like you discussed this to death. BFL, mexwanderer, timetoroll, land yacht etc etc..
So I am the newbie asking stupid stuff...
Yes get 6 volts, stop worrying and enjoy camping...
I have enough solar now, Stop using high use appliances like toasters, coffee pots, and microwaves....LOL.
