- Ric_FlairExplorerChampion
- mena661Explorer
pianotuna wrote:
I think an email to either Honda, Yamaha or Champion is in order Don.
Hi Jim,
My Kipor 2800 watt would reliably start at -27 C. - pianotunaNomad IIIHi Jim,
My Kipor 2800 watt would reliably start at -27 C. - HiTechExplorerFrom PTs other threads I am guessing he may need it in sub zero weather. I don't have any experience at all running any genset very far below 0 that I can recall.
Jim - mena661Explorer
HiTech wrote:
Mine starts down in the single digits no problem (at home typically just to satisfy the monthly maintenance). The coldest weather I camp in is 20F at night and usually full hookups. We don't boondock in the winter.
I wonder how you find out which are easiest to start in cold weather? At least with a portable you can warm up inside first if all else fails to start it.
Jim - HiTechExplorerI wonder how you find out which are easiest to start in cold weather? At least with a portable you can warm up inside first if all else fails to start it.
Jim - big_whiteyExplorer
pianotuna wrote:
Hi,
Unfortunately built in is not an option.
good news is you are now free to buy a good gen set {Y/H} when not limited to a built in. :B - pianotunaNomad IIIHi,
Unfortunately built in is not an option. - mena661ExplorerI second adding a built in Onan.
- mlts22Explorer III'd guess the little starting battery is the limit in the equation, because it doesn't have much power in it, and any more than a few seconds likely would damage its flooded cells.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
