path1
Oct 13, 2015Explorer
RVhiker wrote:
I believe that grease seals for an EZ lube axle are supposed to be constructed with two grease seal lips; does the leaky seal have two sealing lips?
I don't know. Just put on what I was given at time when buying bearings
Was the leaky seal installed evenly - that is, is the flat surface of the seal evenly deep into the bearing hole?
OK, something else to check
Grease seals are supposed to be replaced each time a drum is removed (but I've cheated on this a time or two.) Did you install a new seal or clean up and re-use the old one?
Every time hub comes off (twice now) I put on new seals.
Thanks for the info
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
