jimmyfred
Oct 13, 2015Explorer
path1 wrote:
Second time for one axle grease seal has leaked in about 7,000 miles. Doesn't look like any gouges or out of round or anything else out of place. I don't know what type of seals I have or if one brand is better than another. Axle is AL-KO (now Dexter) with Ez-lube zerk fitting. I hand pack bearings and use Ez-lube fitting very sparingly. Other 3 axles have no problems and I'm doing the same procedure for all of them. I don't think I'm doing anything wrong. Axle is left front on trailer. Weight is not a problem. Tire wear looks the same as other tires, so not way out of alignment.
Question:
Any recommendations for grease seals that are "heavy duty" or known for better quality?
Any hints to why this one axle is giving me problems?
............If I remember correctly , there are Two sizes of grease seals for 5,200 , 6,000 , and 7,000 lb. axles ! 2 1\8th" and 2 1\4".....probably not your problem but could be ! Have your axles been serviced lately ? , jf
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
