time2roll
Oct 27, 2015Nomad
I believe your assumption is correct. In parallel the shaded panel will basically drop out. In series you lose voltage of the shaded section only. I also believe you lose a bit more than 10v per section because you are pushing through the diode.
Typically I recommend all series or all parallel. The series/parallel would seem to be inferior during shade issues. Unfortunately you are probably up against the controller Voc limit.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
