enblethen
Aug 15, 2013Nomad
Ventilation problem!
Check distance from outer wall to cooling unit. Should be down to about 3/4 of an inch. Closing this gap will increase air movement through the cooling unit increasing efficiency.
Look at dimension M. Also look at top of refer to insure that the top is blocked off. Air should not be allowed to come over top of refer. A piece of thin flashing sheet metal bent into a curve will prevent this.
2193 manual
2193 manual
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
