theoldwizard1
Feb 25, 2022Explorer II
BFL13 wrote:
I would be worried the high draw of the inverter would first make for a large voltage drop on the first pair of 6s and trip the inverter alarm before the other pair of 6s could get in enough support. The amps flow between the pairs depends on the voltage diff between them so it can be slower than the discharge rate from the inverter. (That could be bogus, but actual electrical guys can jump in).
I think you are making a mountain out of a mole hill. If you are using the correct gauge wire with quality terminals, this is a non-issue.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
