Just hooked 'em up today. The one on the right is starting to burn oil, so I don't think it has much time left. Anyway, hooking up 3 is no different from 2, although you tell that to the guy at th...
maybe its got a stuck ring pull the spark plug, maybe check compression hand crank to half stroke pour in "Break Free" let soak for a few days drain the 'break free' from the top of cylinder flush with gas, drain gas replace sparkplug fire it up
