Just hooked 'em up today. The one on the right is starting to burn oil, so I don't think it has much time left. Anyway, hooking up 3 is no different from 2, although you tell that to the guy at th...
2OM It was long ago and I usually worked on the larger Hondas and B&S home standby units but let me look at you tube etc a little and see if we can spot anything for you.
Unlikely to be worn out unless it has a zillion hours or had basic bad bore or very sloppy guide etc.
