Jonnygsx
Jan 20, 2014Explorer
westend wrote:
The PD chargers with Charge Wizard, like Pianotuna has, can be switched to overide the automatic voltage sensing. Your single stage charger does not have this function.
If you do get a three stage charger, you may need to upgrade your generator or rely on solar for charging. The Honda 650W rated charger probably won't handle a bigger charger.
Interesting Westend, so when you override the voltage sensing thats when it goes into 4 hour timer mode like tuna said. That seems to defeat the point of a smart charger to me, because you are basically throwing out the tech side and turning it into a timed dumb charger.
