Jonnygsx's avatar
Jonnygsx
3 stage converters while using solar?
Ive been working on getting a solid boondocking solar setup on my travel trailer. Ive wired for 3 120watt solar panels but only have 1 installed at the moment. I still have the original single stage converter in my trailer. I had read that any 3 stage smart controller will be "tricked" by the solar into only float charging. That makes sense to me, as long as the solar is putting in a high voltage the battery charger will read that and go into float mode. So is there any reason for me to bother looking at another converter? I plan to primarily boondock. Until I get more solar i will be using a 650watt honda generator when I need additional power. If I dont get a 3 stage converter how much risk is there to my batteries with this old single stage charger while running the generator?
  • No urgent need to replace the converter. Worst case the generator runs longer than desired. Replace when the converter seems inadequate three times.
  • Jonnygsx wrote:
    So is there any reason for me to bother looking at another converter? If I dont get a 3 stage converter how much risk is there to my batteries with this old single stage charger while running the generator?
    It's just good business to have a 3 stage charger. Otherwise, it's you and a voltmeter and time to determine your batteries' SOC after the sun goes down.
    Any decent solar controller will be 3-stage, but, it's darn hard to bring batteries up to 100% SOC with solar OR generator.
