CA_Traveler
Feb 16, 2018Explorer III
enblethen wrote:Split phase is not needed for the 30+20 amp cheater cord connection as the 50A RV neutral cannot be overloaded.
The two circuits must be on different phases of the electrical source.
You could argue that the cheater cord connected to 30+30 amp (which I've done) could overload the 50A rated neutral if the connection is not split phase.
Update: I was referring to the RV neutral and should clarified that the shorted adapter neutrals can by overloaded.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
