Lantley
Feb 16, 2018Nomad
CA Traveler wrote:
I don't recommend using the cheater cord because there are potential electrical and safety issues that are not understood by most RVers. But as the saying goes if you build it they will buy it. And as stated it doesn't work if a GFCI is involved.
Much better to install a independent 20A circuit in the RV and connect it with an extension cord to a 20A pedestal plug. That circuit could be set up so that a second A/C can be switched to this circuit.
That is how the RV Safepower transfer switch operates.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
