Cptnvideo
May 16, 2023Nomad
I would check the RV breaker panel first. If you have a 2 pole main breaker, then you can plug directly into a 50 amp outlet.
But if you have a single pole main breaker, then where is the 2nd hot wire going?
I assume you know a 50 amp outlet is actually 2 50 amp hot wires, a neutral and a ground.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
