Grit_dog
May 17, 2023Trailblazer
Terry 25 wrote:
Just bought a Puma 25BHFQ. One A/C and a 30 amp camper in every way but the plug and cord are 50 amp. Must I always use an adapter or can I plug into 50 amp if available? Thanks. The camper is on a permanent site with a 30 amp plug. I'd like to eliminate the adapter by installing a 50 amp plug.
You need to call an electrician….
But yes if you wish you could install a 50A receptacle and only use 3 poles of it, it would just be weird and unique and useless as an actual 50A rv power source.
But, like the last guy from a thread a few weeks ago, sounds like you need to verify what’s going on with your situation.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
