cross_country
Nov 29, 2013Explorer
30 amp Hughs Autoformer
After more than 10 years of use in campgrounds, the autoformer seemed to have caused a short which destroyed the pedestal receptacle and tripped the campground breaker. I do not know the electrical consumption at the time of failure. I do know that consumption would be close to 30 amps and that the campground breaker is shared (2, 30 amp breakers together) with another site which must be very close to using 30 amps as well. Oddly enough the front furnace seems to have a board failure, however that may be a coincidence. (new board installed 1 year ago)
perhaps usage exceeded 30 amps or what was available?
continual usage of autoformer 24/7 for 6 months with usage increased as cold weather sets in?
the pedestal receptacle fried and took out the autoformer?
the physical damage was a worn out looking pedestal receptacle which did not work anymore, a fried white wire brass tong and the autoformer no longer working.
plugged the MH into a replaced receptacle and everything ok without the autoformer.
