DrewE
May 31, 2017Explorer III
fla-gypsy wrote:
The receptacle is bad or the park system was overloaded causing low voltage which is hard on plugs and RV systems
Low voltage itself is not hard on plugs. High currents are hard on plugs, and some devices (most notably air conditioners starting up) draw more current for longer when the voltage is low. However, even then the circuit breaker should trip before current enough to cause plug damage flows provided the connection to the socket is solid.
The worn receptacle (or poor connection to its wire) caused a high resistance connection, which caused power to be dissipated in the socket or the plug connection and hence the heating.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
