deepdoc1's avatar
deepdoc1
30 amp power cord overheating
I've searched around and can't find the info I'm looking for. I have a 30' 30-amp shore power cord hard-wired to a built-in Surge Arrest, and I frequently use a 30' 30-amp extension cord for yard camping. I've noticed the prongs starting to show signs of overheating where the shore cord and the extension are connected together.
I occasionally run the AC, and may sometimes forget to switch the water heater to propane while running AC, so that may be the culprit. I am thinking I need to replace the cords, but I had an idea I need to check out with the wizards here.
My thought is to make my own upgraded cords using two 30' lengths of 8/3 or even 6/3 (or 6/3 - 8/1 if I can't find 3 conductor) SOOW from HD or Lowes. My thought is that the OTC 30-amp cords are at their limit with 10 ga, so going fatter may reduce heating issues.
Most other best practices are being followed (for the most part) such as making sure the power is off at the post before connecting or disconnecting the cords, etc. Thoughts? Tips?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
