Denny___Jami
Mar 29, 2013Explorer
smkettner wrote:Denny & Jami wrote:My initial connection is in a metal J-box.
CA Traveler before you start saying it's safe to hook to a 30 to 50 I suggest you look at the way some of the 30 amp cords are connected to the inside the trailer.
You may have a metal J-box but how are the wires connected inside of that box, are they just wire nuts that came come loose over time or never tight to begin with. Loose connections cause heat that raises the temp in the wires causing more resistance causing more amp draw and more heat. Eventually the wire outside the box will start to melt causing a fire hazard. If you are on a 30 and breaker like your system is designed to have you have a better chance of the breaker tripping. You don't have to have a short for a breaker to trip, if you draw over 80% of a breakers rated value for a long period of time it will trip on internal heat just like its designed to do, it's a built in safety factor. I'm not guessing on this stuff, my business was located in a town next to a COE lake and I did a lot of service calls on trailers for just this kind problem. Do what ever you want but remember there are other RVs parked close to you don't make your problem their problem.
As far as EMS or surge protectors I don't use one but they came be useful and helpful if you aren't sure of your incoming power, I always check ours before I plug in if it looks a little less than ideal. I do use a 20amp surge receptacle for the entertainment center to protect our electronic equipment from lightning. They are a one time protection so you have to check them to make sure the green light is still on, if it's not it did its job and will have to be replaced. It will still work but you will no longer be protected.
Denny
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
