time2roll
Apr 23, 2013Nomad
ZZSPIRAL1 wrote:
Hey smkettner, just saw your reponse. Here are some pictures. I don't know what these will tell you, but I don't see a J-box.
I've never posted pictures before (hope this works). Pictures in order: 1. Cable coming from receptacle. 2. Cable going into floor. 3. Just a demonstration of what's under that fidge. 4. Behind converter.
Note, there's a lot of room behind that converter. The oven is above it, though I "wouldn't" necessarily think that's a problem. As always..........thanks.
Well that failed. By chance do you have a Facebook? If so, then you should be able to see the pictures here. Note: the pictures are out of order now, but you get the idea:
https://www.facebook.com/rollin.graham.1#!/rollin.graham.1/photos
Sorry no FB. OK on my trailer the cord comes in the mouse hole and connects to romex at a J-box just inside the wall in the compartment where the cord gets all bunched up when I shove it in. Maybe you have a detachable cord or something else.
If you have space behind the electric panel that is fine also. Just remove the main romex/cord from the panel and connect to the EMS. Get a same rated piece of romex and connect from EMS to the same place in the panel where the wire was removed. This allows you to return it to oem configuration if you ever want to.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 28, 2026
