cavie wrote:
wa8yxm wrote:
Your 15 amp outlet should have a 15 amp breaker UPLINE that protects it. so if you draw say 25 amps.. CLICK and nothing
NOTE: some 15 amp outlets are protected by 20 amp breakers.. NOT a problem if it's fed properly as the outlet itself can handle 20 amps . NOT a problem if it's fed properly as the outlet itself can handle 20 amps UNLESS IT IS A UNI-BOX then 10 amps is the practical limit. And some 15 amp outlets ARE 20 amp (15/20) I have three of those in this RV .
YEP, you probably have them at home to in your kitchen and don't know it. Kitchen counter tops are 20 amp circuits in modern day homes.
OK, IF a 15 amp outlet can handle 20 amps, the WHY DOES IT NOT STATE 20 AMPS? Doug
