red31 wrote:
time2roll wrote:
red31 wrote:
time2roll wrote:
red31 wrote:
Found a 30A RV to 20A receptical!
30/20 adapter
OP, the protective breaker sould be 30A
yes, it would possible to overload its 2500w 20A rating.
I don't think a 30 amp breaker is allowed on a 20 amp outlet.
Supply protects itself.
don't know what has to do with the adapter exceeding it rating without the 30A breaker tripping.
Yes you are correct the 30 amp RV breaker will not trip if you exceed the 20 amps because the 20 amp breaker will have already cut power.
where is this 20A breaker? the appliance is plugged into the adapter, or more than one appliance. Dutch above has the scenario correct.
I think time2roll is confusing a 30/20 with 20/30 adapter.
