GordonThree wrote:
cable wired like this: 30 amp male to two 30 amp female
Does such a beast exist, how would you search for it?
I find plenty of 50 amp male to two 30 amp female cables.
Was recently at an older CG that didn't have spots very well defined, so there were 2 trailers trying to share a power box with only a single 30 amp outlet (and the 15 amp was there but...) rather than flip a coin or come to blows over who's 30 amp outlet it was (not marked btw), I was thinking a y-cable would be a good compromise. sure neither rig could draw the cull 30 amps all the time, but the surge current would be there that the 15 amp just can't supply.
Back to the OP. I highlighted the part of the OP that I targeted with my earlier response. If the OP is intending to get two 30 amp RV on a single 30 amp CB, there are probably going to be issues. Who gets to decide who exceeds 15 amps each. You will not get 60 amps.
