JiminDenver
May 02, 2014Explorer II
captnjack wrote:
How many days per year would you estimate it gets over 90?
It's not a question of how often it can get hot. It has before and will do it again. There was a 10 day stretch in 2012 that we used the AC a few hours every day. There is no temperature level to hit before we use it, when Honey says push the button it's my job to make sure there is a button to be pushed.
I've decided to go with the guaranteed results of a new Champion 3500/4000. Even if a 3100i could do it, I think it will be pushed to the limits causing me to worry that the generator or air conditioning may be damaged. That's no way to spend a afternoon. Remember that there is only a 3 DB difference in the machines when under full load, not worth the risk.
Right now the 3500/4000 with electric start and remote is only $75 more than the basis unit plus wheel kit. I'll get that and spend the rest of the money on a Tailgater dish set up because there isn't any TV reception up there either.
Thank you for the help everyone.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
