Kayteg1
Apr 29, 2016Explorer II
My 15k AC draws 8 amps, the 13.5k does 6 amps.
It is the starting current that is the issue.
With good campground wiring you should be able to run 2 AC s, but being close to system capacity at AC starting you have to try to see.
If you manage to get them both running, make sure they don't cycle. Meaning the coldest setting, or when too cold, turn off one at the time.
Have voltage gauge plugged in all the time.
