wa8yxm
Mar 20, 2023Explorer III
fj12ryder wrote:
Due to the differences in wiring between a 30 amp cord/plug and a 50 amp cord/plug, you'd best be served getting a 50 amp EMS.
However you can use a 50-30 adapter and the park's 30 amp outlet.
The wires in the 30 amp Device are not up to 50 amp loads so do not use the park's 50 amp outlet with it.
As Ryder said. I'd up-grade to a 50 amp unit. Then you can either
A: use the one that fits the park outlet or B: use that 50-30 adapter when in a 30 amp only park.
NOTE you need that 50-30 adapter in any case.
