SCVJeff
May 27, 2016Explorer
smkettner wrote:I wonder. Remember the homes built in the 70's with aluminum wire? They came out with aluminum screw outlets and switches because the wire would spread and get loose over time under hard brass especially when heated under load. Maybe a copper lug add hydraulic crimper can squeeze hard enuf to prevent that?
OK so what is better? I tend to stick with copper.
Long run of fat wire I would be tempted to go aluminum to save a buck.
Same ampacity? Same resistance? Can copper plated aluminum hold a crimp? Does it need anti-oxidation compound?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
