ADAD437
Oct 05, 2019Explorer
DFord wrote:
The 3 flashes is just a code indicating there's a problem. I forget how to retrieve the actual problem code but if you get your owner's manual out and study it, you're find the way to get them to flash. The error code will be two different flashes back to back and then repeating after a slight pause. Once you've got that code and let us know what it is, we can give better advice on what to do to fix the problem. My generator acted like that because the RPMs were just a little high causing the Hz to be too high.
i think after the three flashes you push the stop again and it gives you the second number. mine is flashing 36 but i have not had time to fix it. any ideas?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
