2oldman
Nov 10, 2013Explorer II
4@12v = 24v
I'm installing 4 -12v AGM batteries to power a 24v inverter. This is my first choice for wiring: and my second: Any pros or cons to either one?
DryCamper11 wrote:In my case, both played a role.
I'm assuming one advantage of 24 volts is reduced inverter current draw. My inverter is only 1200 watts and still draws 100 amps. Is that the main reason to go with higher voltages, or does the availability of higher voltage solar play into the decision?
Salvo wrote:Yessir.
Charge controllers are current limited. A 12V battery system may limit solar to 300W. The same controller in a 24V system is limited to 600W, while a 36V system is limited to 900W.
BFL13 wrote:Yeah, 4 12s in series would be sweet. From much of my reading about batteries, it's better to have them all in series.
You could make it all 48v instead of 24v too if you were starting from scratch.
