2oldman
Nov 10, 2013Explorer II
4@12v = 24v
I'm installing 4 -12v AGM batteries to power a 24v inverter. This is my first choice for wiring: and my second: Any pros or cons to either one?
smkettner wrote:X2
In order to properly balance six batteries you will need a bus bar.
BFL13 wrote:You don't necessarily have to worry about voltage drop on the input side of the DC DC converter. As long as it falls within the specs. I'd like to go the 24V route but would need a DC DC converter, 24V inverter and 24V converter (or 24V inverter/charger). Maybe in the next rig.
Still true that it would be better to have the DC DC converter closer to the 12v panel, so the longer set of wires (the input) would be 24v instead of 12v? (for voltage drop)
