2oldman
Nov 10, 2013Explorer II
4@12v = 24v
I'm installing 4 -12v AGM batteries to power a 24v inverter. This is my first choice for wiring: and my second: Any pros or cons to either one?
mena661 wrote:BFL13 wrote:Yes, the watts thing. :) Amp hours is still the important measure here so go with that. IMO, the benefit of high volts is skinny wires (and access to larger inverters) and the use of cheap PWM controllers on 24V solar panels.
I bet this is to do with those nasty watts things again :(
A 150Ah, 48V battery bank has the same storage capacity as a 12V, 600Ah bank (using the T1275's as an example). Watts.
