Moving the neg cable as shown in the dashed line is balanced, yes? (NOT connecting the solid line)
The batts have to sit in that physical configuration in my tray..or at least they used to when I had to water them!
BFL13 wrote:
I can't remember if you are a balancing believer or not.
Where do you tap off your 12v and get your 12v ground to the frame for the 12v items that use the frame for neg to battery?
It's kind of a toss up in my mind, but it can't hurt.
12v tap is a DC/DC converter. I guess the Mfr did the 12v grounding. All I've ever done is ground the inverter.
