rhagfo
Mar 12, 2019Explorer III
wnjj wrote:
Not only that, if a pedestal only has 30A and 20A it may only have wire that can handle 30A, with the assumption that you use one or the other. Larger than acceptable voltage drop may happen.
Not only that but your 30 amp could be on a shared circuit at the main panel. So if all were trying to draw near 30 amps and others on the shared circuit are doing the same, you could trip the circuit breaker at the main panel.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
