- Old-BiscuitExplorer III1984 vintage ........
Bet you have 'GRAY' plumbing lines/fittings
It is 'Quest' piping......Polybutylene pipe
The pipe is OK but the aluminum bands/clamps fail.
If you have Copper crimps or threaded fittings it is OK - ScottGNomadIt will be fine with the 45 PSI pump.
Even when you connect to city water your going to be at least 40~45 psi in most cases. - STBRetiredExplorerMost pumps have a pressure adjustment. You should be able to turn it down, even though you probably don't need to. Most city water connections are higher than 20-30 PSI.
- fj12ryderExplorer IIILeaks? It's about twice the pressure. But it might be okay, probably will depend on the state of your plumbing, or rather the state of your RV's plumbing.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
