Almot
Jul 28, 2013Explorer III
12thgenusa wrote:
I quite often will operate a high demand appliance during the day; MW, coffee maker, hair dryer so voltage will drop well below 13v.
For the OP at 460 watts a voltage of 14.6 or less will hit the 30-amp max. (460*.96/30=14.56)
I am not sure about this math. 96% is Rogue efficiency at 30A (according to the manual), but then there is also 2% lost in cables, so it's more like 14.4V to hit the 30A limit of Rogue at ideal conditions (70F, optimal aiming of the panel and no dust on the glass). Such ideal conditions won't happen at sea level. It also won't happen for users with less than perfect aiming which is anybody but BFL ;)...
But I'm not after those particular numbers here. One thing I don't understand - what "volts" we are talking about. In the absence of charging current, the battery voltage is less than 13, yes. When it is charging, can it be less than 13V?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
