BFL13
Jul 29, 2013Explorer II
My fool-proof way of getting expected AH or amps based on some measurements I made last year, is that 460w should get you 460/130 x 8.2 = 29amps pointed with PWM. If you believe the MPPT guys, add 10% = 3 plus the 29 = 32a
Just when or how long you get those max expected amps "depends" on your set-up, etc.
In cases where you are far enough north of 23N that flat is less than tilted, by "enough" then that could get you below 30 from that 32 I figured.
490w would be 490/130 x 8.2 = 31 with just PWM. Add 10% for MPPT= 34a.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
