Gjac
Apr 11, 2020Explorer III
Also check the coil, heat will cause a failing coil to reduce the spark to the plugs. Check you manual for the proper ohm readings.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
