jarhead83's avatar
jarhead83
4700 generac generator cutting off
In have generac 4700 generator in my 2007 hurricane. The generator runs starts and runs fine. The generator will run the a/c fan great for hours,but once you turn the a/c on it will run about 15 minutes then cut off. Sometimes it will start right back up other times you have to wait 5-10 minutes before it will restart. Once the generator starts you can run the fan again for hours until you cut the a/c on 10-15 minutes generator cuts off. HELP
  • I have not ,didnt know valve clearance could cause the issue. Is that something I can do with the generator in the rv?
  • It should run one a/c. Check your valve clearances.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
