westend
Sep 21, 2014Explorer
Neutral's were not connected fully inside the wire nut. That led to the arcing and the heat. If the neutral becomes disconnected, you will have no power continuous to the RV's load center. Probably no damage to the gen set because no power is flowing through the bad connection.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
