westend
Sep 28, 2014Explorer
NinerBikes wrote:Guilty, as well. FWIW, I've quit trying to jam five or six neutrals in one nut, choosing to pigtail two or three and then combining.westend wrote:
Neutral's were not connected fully inside the wire nut. That led to the arcing and the heat. If the neutral becomes disconnected, you will have no power continuous to the RV's load center. Probably no damage to the gen set because no power is flowing through the bad connection.
This /\. Anyone that's done electrical on residential housing has seen this a time or two in a junction box or in a main circuit breaker. Poor workmanship, not enough stripped wire on both neutrals, and both of them not completely twisted together tight enough before the wire nut goes on.
Good wirenut jobs should never require electrical tape.
Tape..., I sometimes use it, depends on the circumstances. If trying to install more than the usual three into a single gang box and a switch or receptacle, or having cheap wire nuts, I'll sometimes tape them. If Chris Bryant says he uses tape in RV's, that's good enough for me. It's not that much more work and I can see the vibration angle causing a problem.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
