Pathway_Pilgrim's avatar
May 25, 2013
50 AMP connector
I am looking for a 50 Amp female connector to plug into my RV. I have looked at several but mechanically they don't fit. Marinco seems to manufacture them but seem awfully expensive. Are there alternatives? (I have 50 AMP wire).
  • hershey wrote:
    If its the end of the shorepower cord, its a 50 amp plug (male)
    If its the end that the shorepower cord plugs into, its a 50 amp receptacle (female).
    We're all guessing at what the OP is looking for.
    Either way, any electrical supply shop will have it.
    No we're not. OP specifically said "female".
  • If its the end of the shorepower cord, its a 50 amp plug (male)
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If you are talking about the connector that plugs onto the INLET on the RV.. Marinco is your only source far as I know, Check with Marinas as these are marine grade devices.
    The one on the sticks and bricks end of the cord (or power pedistal or post) that one is common.
  • If you have a 50 amp twist lock power inlet on the trailer, you're married to the same twist lock female on your cord. EBay seemed to have the best pricing on the connections when I was hunting for them.
  • The 50A plug is a standard household plug available at hardware stores. Generally these are for indoor usage while the more expensive ones are better suited for outdoor usage.
  • Should be able to find them on-line easy enough. Also any electrical supply house.
