Pipeman
Mar 29, 2019Explorer
50 amp cords
When I connect my 50 amp cord to my 50 amp extension cord, I have a heck of a time getting them apart. Anyone know of a way to make that easier?
philh wrote:Yeah, that was my fear. :)fj12ryder wrote:
it's scary thinking about what can happen if you unthinkingly use the screwdriver before unplugging from power. I've used a screwdriver when my plugs semi-welded themselves together when my EMS gave up the ghost and shorted out. But the idea made me very nervous even though I knew it was unplugged at both ends.
Loud noise, bright flash :)
CA Traveler wrote:I'm not sure what that has to do with anything being discussed, but I imagine most people do. At least if they're equipped with much thinking power.
Well I never plug or unplug with the power on but to each his own.
fj12ryder wrote:Read the posts in this thread related to safety suggesting using gloves and perspiration to avoid coming in contact with power. Not to mention the posts about using a screwdriver to separate the plugs as sooner or later this will occur with the power on.CA Traveler wrote:I'm not sure what that has to do with anything being discussed, but I imagine most people do. At least if they're equipped with much thinking power.
CA Traveler wrote:I did read all the posts, and no where has anyone suggested leaving the power on while messing with the cords. In fact several have reminded people to make sure the power is disconnected. So I'm wasn't sure what the "...but to each his own." statement was referring to.fj12ryder wrote:Read the posts in this thread related to safety suggesting using gloves and perspiration to avoid coming in contact with power. Not to mention the posts about using a screwdriver to separate the plugs as sooner or later this will occur with the power on.CA Traveler wrote:I'm not sure what that has to do with anything being discussed, but I imagine most people do. At least if they're equipped with much thinking power.
Judging from pedestals I've used most do turn off the power before disconnecting but some don't.
