Empty_Nest__Soo
Aug 23, 2015Explorer
The 50-amp outlet is capable of providing as much as 50 amps. The current is limited by the breaker to protect the wiring from service panel to power pedestal.
If you plug in a 30-amp plug using an adapter, you should be limited to 30 amps by the main breaker in your rig, which is sized to protect the RV wiring, e.g., the shore power cord.
The actual current you draw will be determined by how much stuff you are running, and what it draws in the aggregate, up to 30 amps max.
Wayne
Wayne
