ECones's avatar
ECones
50 amp down to 30 amp plug -- still 50 amp?
From the stupid questions department .....
A fellow told us last weekend that when we plug our 30 amp plug into a 50 amp plug through a 50 amp to 30 amp adapter we still get 50 amps. That doesn't seem reasonable somehow, but is that true?
thx ....
  • No. Although it may be possible to draw 50a through the wire, your onboard main 30a breaker will see to it that doesn't happen.
    If I may read into your question a bit, amps are not "pushed" like voltage, so if the fellow was trying to caution you that you may have too much power for some things, it's not true.
  • You get 30 amps through 1 leg at 120V. With a 50 amp plug, you get two 120V 50 amp "legs" for a total of 100 amps on two different 50 amp circuits.
    Edited, my mistake on understanding he is tying into a 50 amp 2 leg pedestal with a 30 amp cord. He'll have the full 30 amp capacity in his RV /TT.
    2oldman below is correct.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
