grampscamper's avatar
grampscamper
50 amp F to 15 amp M pigtail adapter - CSA?
I have a 5th wheel with a 50amp service. I want to order a 15 amp male to 50 amp female pigtail adapter (see link). It shows that the female connector is SS2-50R. Our trailer is CSA approved. Are the 50 amp connectors the same on CSA and non CSA trailers? I want to insure that it is compatible before I order it.
adapter
  • Hi Roy,
    There would not be much point in an adapter that did not power both legs--even if there is only 15 amps to be shared.
  • RoyB's avatar
    RoyB
    Explorer II
    Hi Don - I obviously didn't look very hard huh haha...
    Maybe it helps if you search for 15A to 50A verses 50A to 15A hehe...
    I'm wondering if the TWO HOTS on the 50AMP(F) side are tied together in the connector so that both 120VAC ZONES get powered up.
    Thanks
    Roy
  • RoyB's avatar
    RoyB
    Explorer II
    I don't think I have ever seen a 50A(F) to 15A(M) adapter.
    What I have seen some guys do is use two of their normal adapters they carry to adapt down to the 120VAC 15/20A RECEPTACLE...
    This is a drawing I found on google showing your two 50AMP ZONES being adapted down to a 30AMP Adapter source.
    You will just a second adapter in front of the the 30AMP Adapter shown above...
    You need to have these two adapters to do this...
    50AMP(F) to 30AMP(M)
    NOTE: this adapter will connect to both of your 120VAC 50AMP ZONES in your trailer but will only provide up to 30AMP for both ZONES. The 30AMP breaker providing this power if you are plugged into a 30AMP SOURCE RECEPTACLE will trip if you exceed 30AMPs being drawn by the trailer.
    To get down to a 15AMP 120VAC SOURCE then you plug into this adapter a second adapter 30AMP(F) to 15AMP(M) Adapter to be able to plug this whole contraption into a household 120VAC 15AMP Receptacle
    NOTE: Now you will only be able to draw a total of just 15AMPS from BOTH of your 50AMP 120VAC ZONES in your trailer. If you draw more than 15AMPS of current the circuit breaker of the household 120VAC Receptacle will trip.
    You are safe as no MALE PLUGS you may have out in the open will never have HOT AC VOLTAGE present on them. Only the FEMALE plugs will have HOT AC VOLTAGES present when plugged into a power source..
    All of this sounds like an accident waiting to happen but some folks need to do this I guess...
    Have fun
    Roy Ken
    adapter
    I believe the adaptor shown is a 4 wire twist lock. The ground connection is on the outer circumference marked G in one picture. The 3 connecting blades are W for white (neutral) and X (L1) and Y (L2).
  • dbbls wrote:
    The picture in your link is a 30 to 15. The description states a 50 to 15. I would call them to make sure.
    Thanks. I just sent them an email. Here is the Amazon Canada link.
    Amazon Canada link
  • The picture in your link is a 30 to 15. The description states a 50 to 15. I would call them to make sure.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
