I tested a 50 amp pedestal today before hooking up and got a concern. It had 120 volts to each hot leg but also 120 volts between the ground and neutral. I moved to another site but I am wondering wha...
120 volts between ground and neutral is very much NOT NORMAL, in fact it should be impossible
Are you sure you were measuring from NEUTRAL (Top center) to Ground (Bottom center,round or U-Shaped) The voltage between them should be zero on a mains connected outlet.. In some cases (Running on RV Generator) 60 will show up on a high impedance meter (zero on a low inpedeance meter) but on the park outlet it should always be zero.
